what is this plug harness for?
As some of u can see this harness plugs directly into my reverse lockout coil. The main haness plugs into it via the black rear connector you see. The reason i ask is because the reverse lockout coil doesnt work when this harness in plugged in , but when i eliminate it and plug it into only main harness it does. I just want to know the purpose of this harness to figure out wether i can get rid of it , or repair it. If its the skip shift elim, does anybody happen to know the value of the resistor inside the harness?
