Is my ported tb causing these problems?
I am stumped, my car misfires specifically around 1500 rpms and while I dont feel it, the computer will trigger misfires even with the misfire table maxed out. Also at 1500 rpms if you go through with little throttle it will buck (noticed itll hit lean for a second). (This happens in both maf and mafless sd as well as openloop.)
Car runs great otherwise.
Ive moved around plugs, wires, injectors, coils, valve train seems intact (i had broken a couple dual springs in the past but never had any issues and noticed them so i changed em), etc.
torquer v3, ls6 intake, lts, slp maf, home ported tb (with epoxy and sharpened edges), 150 wet shot, etc.
I am thinking that since 1500 rpms is still within idle table range, the idle valve isn't working optimally and is letting in too much air for a while at the 1500 rpms. I think that this is really one of the last few things that can possibly be wrong with the dang thing (I doubt i have a bent valve because it runs too well and doesnt miss at other rpms).
Any other ideas?
Any other ideas?
Any other ideas?
Any other ideas?
