NOS launcher or FJO digital progresive
Which one would you chose an why?
Are really worthy the extra $160 on the launcher?, or I can go with the fjo an use that money on something else like an interface or a timing tuner, its going to be a plate with a 150 shot an maybe later i'll be adding a second stage of dry (75 shot)
I wouldn't get either for a 150 shot. Set your suspension up correctly and put some decent tires on it and spray that bitch out of the hole. You shouldn't need to progress a 150 shot, unless it's on a 4 cyl. If you plan on adding a second stage then there is really no point at all in getting either one. That is, unless you are gonna spray 250 on the first and 200 on the second...... If it were mine I'd spend the money somewhere else.
