water temp gauge
water temp gauge
I am going to run a dakota digital gauge cluster and I need to install one of thier water temp sensors and it has to be in contact with the coolant. I was wondering where the best place to put this sensor would be. Is there already a spot for a second sensor that I can thread this into?
guage cluster. They are the only company that I am aware of that makes a 12 MM water temp sensor. I also have their guages and have their sensor screwed into the driver side head. Mine is a carb set-up, so I didn't also need the factory sensor. Just look on their web site for the 12 MM temp sensor. No mods are necessary. The passenger head has same opening, same thread, at the rear. Ron
You are lucky, due to the fact that you are going to use the Dakota Digital
