Guess rwhp from ET or mod info?
1969 Firebird: 12.29@115.78 mph on street tires with a fine 2.01 60ft time. 6.0 LQ4, L92 heads milled 10.8:1, L76 intake, 90mm Holley TB, 85mm MAF, 39lb SVO injectors, custom Comp cam (222/238 duration, 581/605 lift, 114+4) Hooker LT, PYPES dual exhaust with an X pipe, 4L60e with all of the good parts inside, TCI 3500 Super Street Fighter TC, 12 bolt with 3.73 gears. HP Tuner tuned. 3700lb race weight.
Any guesses?
Any guesses?
This is pretty entertaining. It did 390 rwhp running bad on the dyno already so his calcs are off.
Geez, if your gonna use my car you may as well have all of the data, here is the HP Tuners log and time slip. You can see where I didn't go WOT for the first 3.3 seconds of the run do to running street tires.
