Wheel bore
Old 04-15-2009, 07:23 PM
mikey67's Avatar
Default Wheel bore
I have 17x9 American Racing Rebels on my car and am looking for hubcentric rings. I know the hubs on the car are 70.3 but does anyone know the bore dimension for the Rebels?
Old 04-20-2009, 04:42 PM
mikey67's Avatar
Bump! Any sponsors here sell hubcentric rings that will work with AR Rebels?
Old 04-20-2009, 06:53 PM
formulaon18s's Avatar
I have the same question, I just installed 18" rebels, do I need these or are they only needed when you use the 5x120 wheel pattern?
Old 04-20-2009, 08:24 PM
mikey67's Avatar
The bore of the wheel is slightly larger than the diameter of the hub creating a gap around the hub center. This can lead to vibration as the wheel may not center properly on the hub when using only the studs to try to draw it on center.
