TT tune question
TT tune question
I will be installing an APS TT in my G8 GT, i bought a new ecm that has the turbo programmed in it as well as new injectors. The company i purchased it from has it running a little rich. Do you guys thinks i should find someone local like Slowhawk to tweak it or what?
A custom tune will definitely make the most out of your setup. The stock tunes they give you are conservative and not set properly for your car to run at its potential.
You wouldn't want to spend thousands to have a cheap tune in the car. A good tuner will put your car on the dyno, then bring the car on the street to make sure it drives well.
Good luck with the setup, it should be nasty!
Moderator
For a Forced induction Tune, you can't get any better than Don (Slowhawk). You will definitly see improved performance as well as a safer tune, having a custom tune over a preset programmer.
Dave
Dave
