Virginia Speed spring engine sale
i figured since the weather was finally breaking and i was in a good mood i would throw are most popular shortblocks on sale
All of these shortblock use new gm blocks that are stressed relieved.they are then machined on our 4 axis cnc.The cylinders are then finished honed on our computerized diamond hone to ensure the straightest,roundest bore possible for the best possible ring seal and minimal breakin.
all rotating assemblies are balanced
and every shortblock is assembled with the proper clearances for what the engine is going to be used for-this is not a generic crate engine that will work in several applications-this is an engine built for your application.
403 budget iron block sb
6.0 iron block
eagle forged 4.0 stroke crank
eagle 6.125 h beam rods
mahle forged flattop pistons and rings
clevite h series rod and main bearings
arp main studs
$4050.00
403 ls2 n/a shortblock
6.0 ls2 alum block
callies compstar 4.0 stroke crank
callies compstar 6.125 rods
arp main studs
$4500.00
416 ls3 n/a shortblock
6.2 ls3 alum block
arp main studs
$4900.00
403 iron block f/i shortblock
6.0 iron block
wiseco,diamond,or manley dished forged pistons
moly rings
arp main studs
$4550.00
403 ls2 f/i shortblock
6.0 ls2 alum block
moly rings
arp main studs
$4800.00
416 ls3 f/i shortblock
6.2 ls3 alum block
moly rings
arp main studs
$5200.00
shipping cost not included in prices
this sale only lasts for 30 days so give us a call not and put down a deposit on one of these great engines
6.0 iron block
arp main studs
$4050.00
6.0 ls2 alum block
arp main studs
$4500.00
6.2 ls3 alum block
arp main studs
$4900.00
6.0 iron block
moly rings
arp main studs
$4550.00
6.0 ls2 alum block
moly rings
arp main studs
$4800.00
6.2 ls3 alum block
moly rings
arp main studs
$5200.00
