what do you guys think?!
Old 04-16-2009, 08:01 AM
dtown_racer's Avatar
Default what do you guys think?!
I was wondering im hopein to take my car to the track within in the next couple of weeks, but i was wondering if you guys could tell me what you think my numbers would be in the 1/4? Obviously il never know what for sure til i go but just wondering if you guys could help me out a lil to what i should expect....
Its a 98 ls1 with ms3 cam, ls6 intake, longtubes, 3inch exhaust, 4:10 gear, small stall and shift kit on a drag radial.......it dynod at 343 wheel hp on a conservative tune...
Old 04-19-2009, 05:13 PM
qwk93ta's Avatar
My guess would be 12.3 to 12.5 @ 112 or so. Do you have any suspension mods? If not, you may not be able to hook.
Old 04-19-2009, 06:30 PM
Tony 2000's Avatar
hard to guess man im like previosely stated 12.3 could be close. Although im runnin a 12.08 stock internals and suspension, and tune. but my car is close to 2890lbs and thats a big factor. But wish u the best and post up ur times im curious to see myself.
Old 04-24-2009, 05:24 AM
darrensls1's Avatar
That's not comepletely accurate. All you need is mickey thompson 255/50R 16 street radials heated up @ 20 psi. I have 100% bone stock suspension with 4.10's, 4400 stall, boltons, cam and fast90. I get 1.55-1.65 60's while dead hooking and even raising the front tires a few inches off the ground.
But with my old Nitto 555R's you would be right. Even with a big burnout I had trouble hooking with a stock suspension.
My guess is you'll get 12.1 @ 113. You need a bigger stall to accomodate the bigger cam. I would go with a Yank SS4000 or Circle-D 4C.
Quick Reply: what do you guys think?!
