is the ls6 pcv setup/valley cover worth cuttin a piece of the block on my 2002 ls1
well i just bought the ls6 valley cover from gm parts and now im really con serned abought cutting that little piece of the block in the valley to clear the ls6 valley cover. is it really worth cutting that piece for it to fit.
Some of the blocks do not require cutting. Mine did and it wasnt really a big deal. Just use a dremel and a small cut off wheel (buy a few). Be sure to block off all openings in the block and tape the heads off so no metal shavings get in there and clean up really well. LS1Howto.com has a decent write up on it with tons of pictures.
if your doing it to prevent oil in your intake...dont bother...lots of people have had mixed results...and mostly still have oil in the intake....run a catch can upgrade to the newer pcv valve or totally remove the pcv system and run breathers(worst option i think....its going to stink
So what's the 'newer pcv valve'? Is it a GM part or aftermarket?
