Header bolts
Old 04-16-2009, 10:09 PM
97camaross's Avatar
Default Header bolts
im fixin to order pacesetter long-tubes and i dont wanna have to **** with exhaust leaks and loose bolts. what are some good header bolts?
Old 04-16-2009, 10:30 PM
1slo_camaro's Avatar
Location: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
ive never noticed a difference in the bolts ive used. i just make sure that everything is in the the right way. and heat cycle it three or four times. and almost let the gasekts break in before and hard throttling. but thats just me. also advance and autozone have the bolts with the tabs on the end that when the start to back out the tab presses up against the pipe and wont let it loosen anymore or the have lockwire. same concept except its between two bolts. i found a link for the lockwire kind.
http://www.autozone.com/autozone/cat...questid=437852
Old 04-16-2009, 11:39 PM
za355tx's Avatar
Get the 1 inch stage 8 locking header bolts. Well worth the $50 they cost to not have to worry about bolts backing out. I've run them on several cars and not had one problem. You can get them from Summit.
Old 04-17-2009, 02:20 PM
RamAir95TA's Avatar
Definitely stick with 1" bolts.
Old 04-17-2009, 02:34 PM
6Speed's Avatar
I bought a set of the percy's splitlock header bolts. Still waitin on them to arrive but I've heard they work great. In the past I've used the stage 8 bolts with locks. The washers are hard to get on and the little clips you have to slide on are a pita.
Old 04-17-2009, 02:38 PM
C5042081's Avatar
def .use 1" because of the thick flange on the pacesetter
1" arp stainless or chromemoly work well,
the stage 8 will give you the option of having a allen head which can come handy
Old 04-17-2009, 02:39 PM
RamAir95TA's Avatar
This is why I went with stainless 1" ARP bolts. I've never had a problem with them backing out.
Old 04-17-2009, 03:57 PM
19mike84's Avatar
im using the autozone 1'' wire lock set and they havent budged a bit
Quick Reply: Header bolts
