Looking for single rear mount turbo will this work
Old 04-16-2009, 10:15 PM
polarischevy05's Avatar
Default Looking for single rear mount turbo will this work
I just picked up a 79 chevy malibu with a ls1 swap th350 3000 stall ford 9 inch 3.73 i'm want to do a rear mount turbo setup on it will this turbo work
GT45 TurboCharger
Wet Float Bearing
External Wastegate
Oil Cooled Center System
Compressor (4 3/16th's Inlet, 2.25 Intake Inlet, 3.25" Outlet Diameter, 69 Trim, .66 A/R)
Turbine (4" Outlet, T4 Flange, 3.5" V-Band downpipe Flange, 92 Trim, 1.05 A/R)
68.7 MM Inducer Compressor
97.8 MM Inducer Compressor
87.4 MM Exducer Turbine
77 MM Inducer Turbine
the motor is stock now and i plan to put a cam in it
do you run a intercooler on a rear mount turbo??? plan on running 10 psi
Old 04-17-2009, 04:08 PM
OUTLAWZ RACING's Avatar
Contact force inductions on the turbo I know a tc 78 series would be large enough and yes put a intercooler on it you will need it.
Old 04-17-2009, 07:11 PM
mk1973's Avatar
GT45 TurboCharger
Wet Float Bearing
External Wastegate
It sounds like the Ebay GT45...I was wondering how they work, once you get it running let us know.
I am in the middle of putting together my DIY rear mount I ended up getting a T67. If you find you need a oil return pump I have a brand new spare I'm not going to use.
Old 04-19-2009, 12:15 AM
it is a ebay turbo for the money hard to beat
Quick Reply: Looking for single rear mount turbo will this work
