HSW bottle bracket mounting.
Here is the bracket I have. http://www.harrisspeedworks.com/shop...&cat=17&page=1
The bracket came without fastners to mount it to the car, so I need to find some, but I was wondering if any of you mounted this bracket above the gas tank, and if so how did you do it? Did you lower the gas tank? Did you use the supplied fastners or use something else? If it's going to be a pain in the *** to mount it above the gas tank then I'm going to mount it on the hump between the rear seats.
Thanks for any suggestions/help.
Nick
Yeah I bought it used, so no allen head screws came with it.
I was doing a seach and saw where someone used a piece of plywood... put the wood under the carpet and fastened the bracket to that... If anyone has done that.. is there any drawbacks, and did you attach the plywood to the car itself to keep it from moving?
Nick
