fans wont work???
Old 04-20-2009, 07:05 PM
jankie93z's Avatar
Default fans wont work???
just put the fans back in and they wont come on tried switching the relays and still nothing anyone have any idea???
Old 04-20-2009, 07:07 PM
ss.slp.ls1's Avatar
Dumb question, but you did plug them back in right? How are you verifying that they aren't coming on? With stock programing, the low speed fan doesn't come on until 226*F and the high speed fan doesn't come on until 235*F.
Old 04-20-2009, 07:10 PM
jankie93z's Avatar
yep i double checked that they were plugged in i will let it heat up and see thanks
Old 04-20-2009, 09:45 PM
shbox's Avatar
You have a 1993? Short pins A and B at the DLC (like you are going to read trouble codes) and see if the fans come on.
Old 04-20-2009, 10:21 PM
the_merv's Avatar
PCM may not be sending the signal anymore..mine did that on my 1995. I doubt you have that problem..just a thought.
Old 04-20-2009, 10:53 PM
Formula350's Avatar
If he does have a PCM, that happened to some gal on here as well, she couldn't get her fans to come on (other than hot wiring) for the life of her!
Quick Reply: fans wont work???
