Computer question
Old 04-21-2009, 04:26 AM
Vadran's Avatar
Default Computer question
I've tinkered with older engines for a while but now I'm building a LT1 383 stroker for my V6 camaro out of boredom and I'm wondering whats a decent computer set up for the thing? I want to keep it fuel injected and need to figure out a good starting place to learn about computer controls for the engine.
Any ideas?
Old 04-21-2009, 06:52 AM
shbox's Avatar
You can use the normal factory computer and be fine. There is plenty of info on the internet and programming/diagnostic tools you can buy to work with it.
Old 04-21-2009, 06:58 AM
DAVE00's Avatar
+1 - Stick with the factory comp. Go with the 94 or 95 model from the fbody as they are OBDI and much cheaper for software/programming of them. 93 is chip based and you will need an eprom burner and chips to change anything yourself and 96+ is all OBDII and much more complicated/more expensive software.
Quick Reply: Computer question
