what kind of power
Old 04-22-2009, 08:30 PM
screming_z28_95's Avatar
Default what kind of power
what kind of power should a cc305 cam make with all boltons and a built bottom end bored .30 ovr
Old 04-22-2009, 10:57 PM
myltwon's Avatar
auto or stick?
10 bolt, 9", Dana60, 12 bolt?
Ported Heads, Aftermarket Heads, or Stock?
Stock compression, lower than stock, or higher than stock?
any reason you went with the cc305? it's a fairly under performing cam and many better off the shelf grinds exist.
Old 04-23-2009, 12:08 AM
gregrob's Avatar
I wouldn't bother with that cam.
Old 04-23-2009, 06:53 AM
dlk1950's Avatar
My mods are listed in sig. Dynoed at 305rhp/314tq.on stock bottom.If I were you with built bottom & bored, I would go bigger, a custom grind.
Old 04-23-2009, 02:34 PM
well i bought the car with the cam in there and finally took it out to c wat it was and thats and it was th 305 and i had stock heads a4 with a built trans 3.73 gear and a 2800 stahl
Old 04-23-2009, 06:11 PM
lt1-xjs's Avatar
Those are stock bolt-on numbers, 330-340 rwhp is what I'd expect from that cam.
Quick Reply: what kind of power
