Search owned me. need help
I did a search for the axle bearing # for a moser 12 bolt. I came across many that said the # was 514003, this is NOT what I have. I do not seem to have the so called press ring that I can see and I do have the O-ring seal on the OD of the bearing. NOW I did get the 514003's and all the dimensions are the exact same as far as I can tell other than the outer O-ring and the inner and outer steel part of the bearing seems to be a bit thicker so It may be a little stronger. So do you think I can have my machinist at work put the O-ring grove in it and GO?
