400 amp alternator
Fosgate T40001BD, plus i made an amp rack with two more amp on top. my fuses add up to 700 amps, I have a optima red top battey and upgraded the big three to zero gauge wiring. When the bass hits my amps fall to about 8
check out mean green http://www.mean-green.com/store/prod...18&SubCatID=34.
Their alternators are usually a little over 300a. Ive never ever seen one dim from too much of a load.
Dan-
Dan-
You'd be better off with two alternators if you really think you need that much. Otherwise you're only going to be putting out decent current at like a billion RPM, and it will suck the rest of the time.
so do i add one of those ebay alternator relocation brackets and find a belt of what. does anyone have a dual setup i can see on our cars. or can i use a truck alternator bracket
