Cylinders 1 & 7 down
So I have a 94z with an LT1. Cylinders 1 & 7 are down when you unplug the injector harnesss on those two the car doesn't respond. Injectors were flow tested and they are working fine. The harness was tested and it is working fine. The wires were teseted and I'm getting a strong spark. Plug 7 has gas on it. Anybody have any ideas?
Going to be doing a leak down test soon. Just wanted to see if I could try anything else before I do though.
well cylinder 1 is back up and running however cylinder 7 is still down. seems to be internal either a bad valve of ring. im taking it to my engine builder this week. hopefully the motor doesn't have to come out.
