Common for newly installed injectors to sap a bit?
Old 04-28-2009, 10:48 PM
sdm1234's Avatar
Default Common for newly installed injectors to sap a bit?
I installed new injectors in the LT1 and upon first startup, the o-ring seals were leaking just a bit on every injector. Is this normal?
Old 04-29-2009, 01:48 AM
beedo's Avatar
No that is not right, did you lube the o-ring before install?
Old 04-29-2009, 07:30 AM
sdm1234's Avatar
Yea, the o-rings were lubricated. Maybe I'll replace the seals and see what happens. It's easy to pop them out.
Old 04-29-2009, 11:00 AM
NonGoggleGuy's Avatar
Did you re-use the stock seals?
Old 04-29-2009, 03:44 PM
sdm1234's Avatar
No they were brand new seals that came with the injectors.
Old 04-29-2009, 11:04 PM
Then I'm not sure WHY they're leaking, but they shouldn't be.
Old 05-01-2009, 09:24 PM
sdm1234's Avatar
Thanks beedo and NonGoggleGuy for your helpful responses. It ended up that a few of the injectors had defective pintle caps and were leaking before the lower seal, so the fuel flooded upward out of the injector opening. So I bought new injectors and I expect everything to be fine.
