How to clean up corrosion on 10 spoke?
I'm going to try and sell my 35th LE replicas soon, so I took them out of storage last night and cleaned them up a bit. One wheel has some corrosion or something on it, do you guys know how to clean it up? I attached a picture of the wheel. Thanks for any help
I think anything that you do to take the corresion off is going to ruin the finish. At the shop I work at there as been a lot of problems with the cadillac 22's on the 08 09 models. I use a die grinder with a green or brown scuff pad. Then go back wet sand over the areas and then clear coat, so it seals it so that will have a harder time coming back.
