tickshift master cylinder installed
Ok gearheads this has to be about the best install for the clutch. I was having so many issues before my switch to the tickshift master cylinder. I went thru 2 master cylinders within 3 months. I am very inpressed with the quality and it took me about 30 mins to install. Install was actually easier than when I installed my mcleod adj. cyl.
I can run through my gears very smoothly even at 5,000 rpm. and the clutch engagement is so much better too. I recommend this part to everyone driving a f-body with a t56 transmission
Nothing if you do it yourself! Im telling you man its too easy, especially if you have someone to help.
I too have loved my Tick adj. master. completely changed how I drive the car. For all the mods Ive done this one seems to have given the most appreciable change in the overall performance of the car.
