LT1 Th400 swap questions
Old 04-30-2009, 08:44 PM
S_carve's Avatar
Default LT1 Th400 swap questions
Ok guys here it goes... I did the read the Th400 swap thread but it all seams related to LS1. I just picked up a 95 Z28 with a shot 4l60e in it. I already have a bone stock Th400 short tail that I want to swap in. I also have the proper length Spohn driveshaft and a body mount TA setup.
What I did not pick up from the swap thread was do I have to do all the same things for a LT1 based car. Like the shift cable mod should be the same as a LS correct? But the Torque convertor setup as far as the pilot length and flexplate placing, what do I use for these? Can a regular Th400 Convertor work? And will the engine run fine, minus the check engine light for the trans sensors?
Any help or other links appreciated
Old 04-30-2009, 10:59 PM
Closed ex-Sponsor Account
tptransmission's Avatar
Yes it will work with the regular converter and flex plate. Just verify the gap is no more then 3/16" between the lugs and the flex plate. As long as the ECM know what PRNDL position is it will be o.k.
Old 05-01-2009, 05:32 AM
S_carve's Avatar
so a regular th400 converotr is ok and a regular LT1 flexplate is ok also?
Old 12-25-2011, 03:55 AM
StraightTimeStirrups's Avatar
I am trying to find the same information. Can you tell me what you did (all parts required to make the switch)? I am going T56 to TH400 but all of the basics will be the same.
Joe
Quick Reply: LT1 Th400 swap questions
