FPR Required?...
Old 04-30-2009, 11:47 PM
LS1Silverado05's Avatar
Default FPR Required?...
Is a boost referenced FPR required on all builds or just the big ones?...
(im only looking for 450-500rwhp to start with)
ill be running dual walbro 255s... to a T70 Manifold Build on a stock long block... will I need a FPR of any kind or just run it direct?...
If one is required...what do you guys recommend for this mild build?...
Old 05-01-2009, 07:49 AM
smokinHawk's Avatar
you can use the stock FPR. and unless your planing to up the HP soon, id just stay with one walbro, should be plenty for the power you are hoping for.
Old 05-06-2009, 12:20 AM
hmm.. You think one pump will flow enough?
Old 08-01-2009, 10:26 PM
taws6m6's Avatar
I am interested in this as well. I was under the impression I HAD to get a boost referenced fpr. I have roughly the same hp goals as the OP
Old 08-03-2009, 11:39 AM
Customizing Director
MadIceV8's Avatar
A single pump with a hotwire kit is easily good to 450-500.
Old 08-03-2009, 11:56 AM
RooRnZ28's Avatar
while the BR fpr is not required, it sure would help. When I had the stock setup, my fp would drop 8-10 psi at the rails when in boost. Now, it doesnt go below 50psi and even rises with boost pressure.
