General Maintenance & Repairs - Ls1 tune up
dickeymoore
05-01-2009, 11:55 AM
I have a 2001 Z28 with 82K miles on it and when is it a good time to tune it up and any help on installing the plugs and wires?THANKS
NSSANE02
05-01-2009, 12:13 PM
If you don't know the last time it had service done, now is a good time. What kind of help are you looking for on the plugs and wires? Might as well run some seafoam through it before you service it too, then change you oil/filter, fuel filter, ect.
dickeymoore
05-03-2009, 05:30 PM
What is SEAFOAM and where do I get it,how hard is it to change plugs in my 2001 Z28?
NSSANE02
05-03-2009, 05:38 PM
Seafoam is an engine/fuel system cleaner, you can find it at any auto parts store. If you have stock exhaust manifolds the plugs may be a pain to get to but it's still a pretty easy job.
loyolacub68
05-04-2009, 11:23 AM
Have fun with the number 8 plug. I found for me it is easiest to get to that plug from under the car. I would replace the oil/filter, fuel filter, rear diff fluid, tranny fluid if its not already brown, run seafoam (you can get it from Autozone or NAPA, see this thread for how to do it http://www.ls1tech.com/forums/general-maintenance-repairs/534376-how-seafoam-your-car.html), check brake pads for wear, coolant flush, check radiator hoses, change power steering fluid......am I missing something?
Medic/Z28
05-04-2009, 11:43 AM
Dont forget to clean MAF, change belts, Thermostat, and maybe think about O2 sensors.
Black FormulaLs1
05-04-2009, 11:46 AM
change the thermostat to a 160 ....if you gotta change it up grade it...and dont use a damn FRAM filter..wicks, purolater and a good synthetic , MSD wires, NGK Plugs, K&N air filter...if you want to know more let me know..
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
