What does "REVERSE SPLIT PATTERN CAM" mean?
Old 10-30-2003, 10:03 PM
Okie02's Avatar
Default What does "REVERSE SPLIT PATTERN CAM" mean?
i was looking on texas speed and i seen a couple of cams that said this...what does it mean? thanks
Old 10-30-2003, 10:09 PM
someday's Avatar
thats when the intake duration is bigger than the exhaust duration... like their 228/224 cam...
Old 10-30-2003, 10:15 PM
jrp
SN95 Director
jrp's Avatar
what ^ he said. i got the TR 230 which is a reverse split grind. from what i've read, reverse splits are optimal for N/A motors as long as your intake and exhuast is setup for it.
Old 10-30-2003, 10:24 PM
Okie02's Avatar
ok thanks guys
Old 10-30-2003, 10:29 PM
Cstraub's Avatar
Reverse splits are not optimal. Optimal is when a cam is designed to produce maximum power out of an induction system for a specif power band. Reverse splits are designed to do this with induction systems where the exhaust is very efficient.
Old 10-30-2003, 10:34 PM
Ferocity02's Avatar
What would be considered "efficient" exhaust and intake? LT headers, not cats, true duals, LSX manifold, 85mm MAF, etc.....???
