heads and cam
Old 05-01-2009, 09:11 PM
markwaterman's Avatar
Default heads and cam
I have stock heads that i am sending off to the shop any advice on wha to mill them to and what size valves to go with? also what is a safe cam size to go with ? it will be my daily driver also. come on guys give me some good advice
Old 05-02-2009, 12:29 AM
James Montigny's Avatar
First make sure the shop you are working with is reputable and has
experience with LT1 heads. (References with Lt1s are good)
Talk to the shop, get a feel for what they do and don't know and how they treat customers.
Cam selection depends heavily on things like vehicle weight, purpose,
rear end gear ratio, budget and future plans. With a stock bottom end,
something between 224/230 and 230/236 is about as big as you want to go.
Otherwise, you end up with a powerband you can't reach without spinning a rod bearing.
(FWIW: I DDed a 224/230 cam with my LE2 heads, it was awesome )
Most professionally-ported heads end up with either 2.00/1.56" or 2.055/1.60" valves.
It really depends on the application and portwork.
My advice is to poke around and see what others are doing, see what works
and what doesn't before sending you heads off to a shop. You could save
yourself form wasting $2000 and having your heads ruined. There are literally
hundreds of Heads/Cam threads in this section.
Old 05-02-2009, 11:59 AM
FbodyFreak's Avatar
^^^^^ agreed. There are dozens of thread in this section with people asking the same question.... again i reccomend LE(Lloyd Elliots) & AI(Advanced Induction) they are known for their stock head porting and great cam combos...
Quick Reply: heads and cam
