Think ima need a 9" help with a few questions..
well this is my first fbody .. but anout the 3rd lsx powerd car ive built ..
im pretty sure im going to need a new rear end in the future . motor and botle should be making well ofver 600+rwhp and torque ..
had alot of questions regarding this ..
im looking into a bullet proof 9"
but dnt knw if i need a 3 -4 channel tcs thing or how much it should be lowerd or anything else to do with it ??
new to the f body and dnt knw much about mine except that the rear end and suspension is 100%
is there any vender i can buy a complete rear and just bolt it in ? not trying to take it to any shops or anything else ..
also what options should i buy it with ? wich spool or splines ? and were can i find the best deal for a complete bolt in rear end . thanks !!
For the power you are going to be producing you should be looking at either the locker or a spool. I have these options at the above link.
3 channel means you only have ABS. The connection going into the rear will be on the top of the center section if you only have ABS.
4 channel means you have ABS/TCS TCS stands for traction control, and you would have a traction control switch on the dash. Your connections going into the rear will be outboard by the brakes.
If you have any other questions, let me know. Thanks. Bob
