what fuel pressure are you guys running with nitrous outlets 90mm plate?
LS1TECH Sponsor
If your feeding the plate with your factory fuel system, you will be running 60 psi fuel pressure so you will want jetting to match. If you have a dedicated fuel system, then you could run 10, 45, or 60psi fuel pressure and would need jetting to match.
