Oddball headlight question/issue...
Okay, so when I go to turn on the headlights in my 98 Formula, and all 4 lights come on (low and high beams) even though the high beams are not engaged. All four lights are dim. Then when I engage the high beams, all four go bright, and when I go back to low beams now, they are just how they are supposed to be (two normal lit/bright low beams). And then everything is fine. But when I turn off the car and try it again (turning on the headlights on low beams) I get all four dim again and the whole process is the same as before.
The battery seems to show good/normal voltage on the dash as perhaps a low charge was my first thought.
I'm really baffled on this one. Anyone have any ideas on whats going on with my Firebird?
It sounds like a bad ground on one of the harnesses. Same thing happened to mine. Check the clip for the lights/ motor just above the front marker light mine was in bad shape. Wires and connections were rotted to hell. Found out it was a bad ground.
