STS Oiling System Issues - Please Assist!
ALL -
I have a 96 LT1 M6 Pontiac Formula that I am fitting a Squires Turbo system to. My current issue involves getting pressurized engine oil to the turbo.
I’ve been told by Tech Support at STS that the braided steel line which feeds oil to the turbo is simply: “attached at the oil sending unit, which is either: near / directly above the oil filter, or on the pass side of the block, in the same general location” – it would be simple too, if I could find this elusive object!
Earlier this year, I changed the oil pressure sending unit, which was located behind the intake manifold, near the heads, almost touching the firewall; and Chris, Tech Support @ STS, told me that was NOT the correct port, rather it was lower on the block.
I found a port, with an unknown one-wire sensor attached, but the Tech at my local Pontiac dealership thought that object on the pass side pic of my block might be a Coolant Temp sensor, and NOT an Oil Temp (or Oil Pressure) Sensor, so, I am a bit confused.
I’d really like to just do this once and minimize my car’s downtime.
I’ve attached pics (off my camera phone) of both the driver’s and pass side of my engine block to aid / assist in this activity.
The driver's side, just above the oil filter, has a plug with a 6mm recessed / allen head, but that sucker will NOT move ( ); and, as stated above, the pass side has a one-wire sensor, just above the oil pan and in front of the starter.
Can someone (who has done this in the past) please assist in determing the correct location that I should tap into to get pressurized engine oil back to my turbo?
Please: point to / confirm the location / draw me a picture / take a shot of their vehicle / etc… so I can correctly tap into my vehicle’s oiling system, and ultimately overcome this latest hurdle in going from Normally Aspirated to Forced Induction – Thanks!
MIKE
MIKE
on the LT1 there is a port right above the oil filter that u take off and its a direct oil spot i this its a 1/4 inch or 3/8 plug that u use a ratchet to take off but its right above the oil filter thats what u want to use
Maybe / Maybe not
Witry -
I appreciate the info / input, but (on my car) that 1/4" or 3/8" port does not seem to exist; unless it's the object in the first attached pic, then it's a 6mm allen headed plug.
Can someone who's done this on an LT1 chime in please?
http://shbox.com/1/aux_oil_port.jpg
Two votes for the Driver's side
Witry & Mk1973 -
You guys are both pointing to the same object, so Witry, I owe you an apology. You were indeed correct.
However, mine (unlike the one on shoebox's site) does NOT have a larger hex head - in the pic @ http://shbox.com/1/aux_oil_port.jpg - to twist, but rather a recessed / 6mm allen head style. I'm sure if it had the larger hex head on it I'd not be trying right now, I'd be finishing up my oil line install.
This morning, that sucker just would not move!
I broke two hand tools (and slightly rounded the head) trying to get it off today.
(Oh, the object in the second pic is my knock sensor. I determined that after searching thru my GM 96 F-body Manuals about ten minutes ago.)
So, any suggestions on removing a stubborn plug?
PB Blaster?
Heat?
Dynamite?
A Second Idea:
What about the port used for the oil pressure sensor (as seen in http://shbox.com/1/aux_oil_port.jpg) - would this port work if I could not free the plug near the oil filter?
LMK!
PB Blaster?
Heat?
Dynamite?
A Second Idea:
LMK!
Hope this helps, I am in the middle of a rear mount build/install and this is where I got my oil feed for the turbo...I have a 95' LT1 Camaro
