Oil Pan gasket
Old 05-07-2009, 03:30 PM
00_Z-28's Avatar
Default Oil Pan gasket
Can you replace the oil pan gasket with the motor still in the car? I have my trans out and my oil pan has been leeking bad so I figured this would be the best time to replace it if it can be done.
Old 05-07-2009, 04:23 PM
CaliboyTA's Avatar
i hook the engine to the engine hoist. unbolt the motor mounts, unbolt the steering linkage, and unbolt the k-member and dropped it down couple inches to reach the oil pan bolts. the engine was still in the car but unbolted to the k-member.
Old 05-07-2009, 10:36 PM
00_Z-28's Avatar
Ya I was afraid that it was going to be something like that I was looking and it didn't look like there was any way to do it without "pulling" the motor so to speak.
Old 05-07-2009, 10:43 PM
jrpimp00's Avatar
actually not that bad as everyone makes it out. I did mine a couple pf month ago (first time on a ls1). about 6 hours of actual work over a 2 day period.
Old 05-08-2009, 06:32 AM
NonGoggleGuy's Avatar
It really does make one wonder... for the most part, GM has always made things "relatively" doable for the home mechanic... then you get to the F-bodies and it's a ******* nightmare.
