M6 shifter issue (hurst billet plus)
Old 05-07-2009, 05:21 PM
Ironxcross's Avatar
Default M6 shifter issue (hurst billet plus)
I have the hurst billet plus shifter, I noticed an interesting noise coming from the shifter the other day, sounded almost like can of change vibrating. It would only happen in certain gears at certain rpm. I took apart the console and found the culprit. Further down on the shifter stick, there is a metal piece that goes across, forming an intersection. In this, there are two small metal poles that stick out and go into the sides of the shifter (where the springs are). The drivers side of this area has play in it, the other side doesn't. I took out the sides and looked at the springs and they were fine. I put some grease in there, thinking it might help, but I doubt it.
Do I need a new shifter or do I just have one thats going to sound like change rattling for a while?
Old 05-07-2009, 05:24 PM
tripps's Avatar
There are alot of bolts in that area, have you checked all of them? Also, with a cutout a lot of things vibrate after a while.
Old 05-07-2009, 05:57 PM
Ironxcross's Avatar
All bolts are tight.
Old 05-07-2009, 09:01 PM
Save the manuals!
wssix99's Avatar
http://www.hurst-shifters.com/c.7230...r_rebuild.html
Old 05-07-2009, 09:36 PM
Ironxcross's Avatar
yeah... $90 is kinda steep to take 4 bolts off and put a new spacer in there.
Old 05-07-2009, 10:21 PM
IHEARTLS1's Avatar
Thats no good. Might have a hairline crack somewhere causing the sound your experiencing, if all the bolts are tight. Might be time to check into a new one.
Old 05-08-2009, 12:48 PM
Ironxcross's Avatar
Well I talked it over with summit and they said it has a lifetime warranty. So......... I'm getting one for free.
