nx hitman plate used as a dry kit?
im looking at getting the nx hitman plate as my first stage but i want to use it as a dry plate. the question is can i put a nitrous line in the fuel port (with propper jetting) and it work? thanks for the help
i have the interface to control the fueling for the dry kit through the plate and my direct port is wet. if i just use nitrous jets in both the fuel port and nitrous port do you think it would work. its going on a vic jr.
You will need to flow the plate on the intake and make sure that all cylinders are seeing an even mixture. I have not tried to flow the Hitman on the LS1 victor intake. Personally I would rather use the system the way it is intended rather than trusting the method you are planing but everyone has there own methods. As far as the fuel VS Nitrous side on most designs you will be fine with running nitrous through both sides.
Dave
Dave
