issue after intake manifold gasket and water pump rr
Old 05-08-2009, 09:39 PM
phirepower's Avatar
Default issue after intake manifold gasket and water pump rr
replaced intake mani gaskets and water pump on 1994 Corvette. car started right up after everything was plugged back in. Now the car will not start, owner has informed me smoke smelling of fuel was coming out of his air filter. Any ideas?
I believe the opti was soaked when we pulled the water pump but the car fired right up afterwards...
Old 05-09-2009, 10:53 AM
phirepower's Avatar
any1???
Old 05-11-2009, 02:49 PM
Mr_Bond's Avatar
Most likey, if you soaked the opti, the opti is toast. I would run the no start "tests" before throw a new one on.
Quick Reply: issue after intake manifold gasket and water pump rr
