lt1 4 bolt main
Old 05-09-2009, 04:55 PM
1toofastlt1's Avatar
Default lt1 4 bolt main
witch cars came with the 4 bolt main lt1. i have a 97 z28 lt1 will that have it?
Old 05-09-2009, 05:04 PM
sohc19974.6l86's Avatar
yours is a 4 bolt main.
Old 05-09-2009, 05:18 PM
The Batman's Avatar
No, only the corvettes came with 4-bolt mains and the f-bodies came with 2-bolt mains.
Old 05-09-2009, 05:55 PM
AChotrod's Avatar
some guys got lucky with the leftover vette blocks from 96, If your very lucky a 97 could have a 4bolt. Other than that only if you bought a LT4 car.
Old 05-09-2009, 06:01 PM
so is there a code in the vin or the build code somewhere that says if its a 2 or 4 bolt main?
Old 05-09-2009, 06:18 PM
AChotrod's Avatar
nope, just pure luck when you pull the pan
Old 05-09-2009, 06:22 PM
O ok i hope mine is
Old 05-09-2009, 06:24 PM
AChotrod's Avatar
everyone with a 97 Hopes.. my old 97 didnt
Old 05-09-2009, 07:12 PM
fergymoto's Avatar
Chances are your 97 doesn't. Don't count on it.
Old 05-09-2009, 10:38 PM
uselessracing's Avatar
Mines a 4 bolt
Old 05-10-2009, 07:42 AM
Rob
Rob's Avatar
Mine is a 4 bolt but that was a crate engine Got that under warranty when the pickup fell off and spun the #4 rod bearing.
I have never heard of anybody getting anything but a 2 bolt main in a F-Body, save for the LT4.
Old 05-10-2009, 09:06 AM
96capricemgr's Avatar
Rob makes a good point, warranty engines were 4-bolt, as well as the Vette, LT4 and a few oddball late production f-body LT1s.
That said by the time the 4-bolt becomes meaningful you should be putting aftermarket caps on it and that requires a fair bit of machining so you aren't really gaining anything by having a factory 4-bolt. Well other than weight.
There is only one LTx casting for the block.
Old 05-10-2009, 09:19 AM
nichols92's Avatar
Originally Posted by uselessracing
Mines a 4 bolt
Really? I have heard that the only camaros with lt4's were ones that had the engines replaced.
Old 05-10-2009, 09:52 AM
3DFORMULA's Avatar
I bought an x police camaro with a replacement motor and it is a 4bolt. It also has NO oil cooler on it, which might help some id a replacement motor.
Old 05-10-2009, 11:34 AM
engineermike's Avatar
There is some mis-information in this thread. ALL corvettes had the 4-bolt main blocks (LT1 and LT4), and a select lucky few '97 f bodys.
Old 05-10-2009, 07:19 PM
I don't see where anyone suggested any Vettes got 2-bolt.
Old 05-10-2009, 07:38 PM
Not all lt1's are 2 bolt, just most of em in the f- bodys. I got an the lt1 out of a 92 vette, the first year lt1's were put in em, and its a 4 bolt.
Quick Reply: lt1 4 bolt main
