truck manifolds
truck manifolds
Hello, I want to use the tried and true truck manifold set up for my turbo build. I have a fully built 382ci and im using 317# heads, of course lq4/9 manifolds will bolt up, but what about manifolds from 2008,9 trucks? They use l92 heads I believe, are the exhaust ports so different that that the two would not match up or is this not a issue? Also do you guys use the factory exhaust gaskets (between heads and manifolds) in these high hp builds or do you use something fancy like kooks or sce? Thanks.
