Nano questions
Nano questions
How are the nano systems working for you guys at the track? Are you seeing better results? More MPH? I can see it being easier than a heater on cold days and getting a few more passes, anyone with before and after results?
I like my NANO because each and every pass is consistant. Right down to only a pound of nitrous left in the bottle. I got another two good passes out of a bottle with the NANO.
However, I didn't get an ET or MPH improvement with the NANO like others have. I also didn't have to re-jet my fuel pills. The air/fuel ratio was the same both pre and post NANO.
For me the consistancy in the brackets and getting to use all of the nitrous in the bottle is worth it.
I had a good gain before and after with nano. I upped my fuel pill and before nano only ran my bottle at 900psi. After with the nano car ran at 1050 psi and i picked up .4 and almost 5 mph. Car left a lot harder with the extra bottle pressue (did a test launch with bottle at 1100psi and car left almost as hard)
