GM LSX-DR Cylinder Heads P/N 19166979
Old 05-12-2009, 08:59 AM
FastBlackTA's Avatar
Default GM LSX-DR Cylinder Heads P/N 19166979
Has anybody heard or used these cylinder heads in an LSX based application?
This would be on my nitrous'd Drag Radial Trans AM
19166979 NEW
LSX-DR Cylinder Head (not shown)
• 356-T6 aluminum racing head
• 5/8" thick deck
• LSX-DR rectangle intake port design—requires LSX-CT
or LSX-DR intake manifold
• LSX-CT/DR spread port exhaust port pattern
• Cast-in down-nozzle bosses (not machined)
• Designed for up to 2.28" intake and 1.62" exhaust valves
(4.165" minimum bore)
• Fully CNC ported
• Machined for 1.66" valve springs
• 11° valve angle
• Minimum 4.125" bore
• 313cc CNC’d intake ports
• 116cc CNC’d exhaust ports
• 50cc CNC’d combustion chambers
• Capable of over 900 naturally aspirated hp!
Old 05-12-2009, 09:10 AM
nastychevelle's Avatar
i read about these in CHP the other day they seem legit, i say try em out and let us know
Old 05-12-2009, 01:49 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
I say.....they are not available yet....but also, you will need to use the special manifold with those heads...so make sure to buy that too
