reluctor wheel help
reluctor wheel help
can i take the reluctor wheel off my factory Auburn 10 bolt carrier and put it on a
factory zexel torsion unit i am buying it doesnt come with one
thanks ahead of time for all the help
yes,I do it.Be careful as the 'reluctor' is prone to cracking if not removed properly and installed properly.
The GM parts manual shows 2 different part numbers for the reluctors with reference to the 'GU' axle codes.It appears the GU2-2.73 and GU4-3.08 get one part number and GU5-3.23 and GU6-3.42 get the other part number.Since the carriers(2 series vs 3 series) are about a 1/4" difference in the position where the ring mounts in relation to where the sensor in the rearend sits,one of the rings might have offset teeth.
