Drag Racing Tech
Post up your rears!
Old 05-13-2009, 06:29 AM
98Camarod's Avatar
Default Post up your rears!
I've finally made a good sales pitch to the wife and I've been granted an allowance. I'm doing my research before I dive into this. My car is a weekend warrior/drag car. I plan on getting a spooled, 35 spline, nodular iron cased 9", undecided on the gears, but I'm running a 28" tire. I'm a turbo car, so if you have any advice on the gears let me know. I run mainly 1/8th mile, but I'd like to be able to take it to the 1/4 mile track.
Lets see your setups! Post the power that your making, 60', brand, feedback on the its performance, and price if you don't mind.
Old 05-13-2009, 08:22 AM
LS1TECH Sponsor
Steve Burger's Avatar
Check our site. We have a lot of info. We do many rears for the turbo guys here and on yellow bullet.
Old 05-13-2009, 10:22 AM
98Camarod's Avatar
I didn't see them as complete packages on there, any price on those?
Old 05-13-2009, 10:45 AM
kp
kp's Avatar
I'm using an M9 Moser and have no real complaints, if you dont have a good torque arm moved off the trans then buying the whole thing with their torque arm/trans crossmember isnt a bad deal. The rod end front is a bit harsh for street driving IMO. I have gone 1.33 60 foots so far on it (not really trying hard) and its probably 40lbs lighter than their regular 9" with another brand torque arm/trans crossmember.
But
I have gone 1.25-1.27 (best 1.23) 60 foots with a regular Moser 9 inch , random tech torque arm and BMR trans torque arm relocation bracket/trans crossmember. Its a bit more street friendly setup with the stock type bushing in the front and for exhaust clearance.
You will get 100000000 different answers on this, a 12 bolt is more efficient but I dont like farting around with rear ends. Put a 9" in and its done. As far as gear I used a 3.70 with 28" tires to go anywhere from 10.40s to 8.90s with the same car and its still streetable with a 3 speed auto, if you are going to keep your OD it depends what you plan on trapping fro MPH and rpm, dont want to shift into OD in the 1/4.
As far as pricing Bob at EPP has the all the Moser prices/options on his site. A rear end is a pretty simple piece and the engine/suspension/tuning is more important than who makes the housing - plenty of good ones out there. I have had very few issues with Moser and you cant beat getting it in a few days..
Attached Thumbnails Post up your rears!-94.jpg   Post up your rears!-p9280370.jpg
Old 05-13-2009, 12:46 PM
Fireball's Avatar
std moser 9" housing with backbrace option (narrowed 3.75" per side)
moser aluminum center + 35spline spool...assembled by yours truly
1200+ rwhp
1.36 60' so far
Bought this rear 2 yrs ago when I first started my turbo project...before all the fab stuff came out for the f-body...but I do like that I use a traditonal stock-style torque arm mount in the back...
Old 05-13-2009, 07:09 PM
98Camarod's Avatar
kp, what spline axles are you running?
What kind of limits are on the 31 spline axles?
Old 05-13-2009, 07:23 PM
HSESWS6's Avatar
I have a Midwest Chassis Fab 9 with back brace, 35 spline axles, a spool, and 4.56 gears
This is the best picture I have of it since I am at work
03 BUSA's Avatar
Midwest Chassis fab 9 inch with backbrace. 35 gun drilled with spool.
Old 05-13-2009, 07:33 PM
kp
kp's Avatar
35 spline, I wouldnt bother with 31 spline stuff really, as far as I know they cost the same.
Old 05-13-2009, 08:07 PM
LS1TECH Sponsor
Let me know what you want. We build to order or can get a Moser. We match the EPP price on those. We can set you up with the rest of the rear suspension as well.
I need to know what to price as they all vary. Is it a street car, do you want brakes or a pro gear, what options can we include? We have tie downs, built in anti roll bar, wheelie ar brackets, and so on, Will it be narrowed?
All of ours have fill and drain, built in LCA relo brackets, and a back brace.
Old 05-13-2009, 11:59 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I really like the MWCP pieces for the price.
Old 05-14-2009, 01:40 AM
night ryder's Avatar
midwest 9. 35 spline gun drilled, spool. midwest is the best deal out there by far.
have seen one of his rearend go into the mid 6's (1/4 mile) with a 10.5 car.
Old 05-14-2009, 01:52 AM
OWN3D BY MY PROF!
If you can also swing the little extra money I would get the axles gun drilled for reduced weight and added strength.
Old 05-14-2009, 05:12 AM
98Camarod's Avatar
I can tell you that I can't afford that much right now. I'm hoping to find a used one
Old 05-14-2009, 06:15 AM
z28rob18's Avatar
bought my moser 9" 33 spline axles with a locker used got it and all the rear suspension parts for 2500
Old 05-14-2009, 07:49 AM
amsoilguy's Avatar
I'm in the market for a rear end right now and there are to many choices!! Midwest is looking like the best deal so far $3900 for everything which includes the custom driveshaft. You end up getting more for less than anywhere else I have seen so far. If you drive hard and have a 6 speed car dont waste your money on anything else just go 9"
Old 05-14-2009, 08:04 AM
96LT1355Z28's Avatar
Another MWC 9", 31 spline, TruTrac, 4.10's, ARB
Attached Thumbnails Post up your rears!-3.jpg   Post up your rears!-img_3052.jpg   Post up your rears!-img_3047.jpg
Old 05-14-2009, 10:18 PM
Taubr Unit's Avatar
MWC hands down!! At least call Eric and talk to him, super cool guy and likes to talk a lot, lol....
In RAW form to see the fine details of it..
Old 05-15-2009, 06:27 AM
amsoilguy's Avatar
I want that MWC 9" sooooo bad. That thing is beautiful. I will have it soon.
Old 05-15-2009, 11:23 AM
LS1TECH Sponsor
At 3900.00 we are very competative. We also supply all of the rear ends to the major builders and racers on this board, as well as a lot of other race teams.
Quick Reply: Post up your rears!
