408 Heads
Old 05-13-2009, 02:31 PM
BlackTA96's Avatar
Default 408 Heads
So i'm thinking about going 408,
But the heads i was going to use for my stock cube 6.0 are gonna be a little small for a 408 i think. Was gonna go with PRC stage 2.5 5.3's
You guys think they'll be to small for a 408?
what head would the recommend?
Motor's still in the planing stages right now so i'm open to offers.
Old 05-13-2009, 02:45 PM
vettett15's Avatar
I believe there were a couple 408 setups using the 2.5 5.3's, if you check out the sticky in the dyno section.
Old 05-13-2009, 02:48 PM
MASS seller approved
smok'nZ's Avatar
afr 225,dart 225's, t f s 235's,l92's, something like those
Old 05-14-2009, 09:11 AM
BlackTA96's Avatar
Im lookin for about 500rwhp.
would cnc l92's do that for me?
Tryin not to go to an aftermarket head. $$$
Old 05-14-2009, 09:24 AM
99blancoSS's Avatar
Yes with the right cam the L92's should work but they are $1800 anyway. PRC has a 237cc that is worth looking at as well on top of a 408. I will be carrying PRC shortly.
Example for you: 408 with PRC LS6 stage 1 heads and an MS4 cam put down 470hp out here and 420 tq IIRQ. I think he had an Ls6 intake as well.
It's a budget choice.
