tire pressure
When Im running my sumis for long trips i like to run 25-30 psi. when im running around the streets i like to get them down to 18-20 psi bc they hook a lot better. they get pretty soft and you can actually feel them mush down to get traction. it seems helps street tires. it also causes a bit more wear on the outer edges of the tire but for more hook its worth it I think. DRs i run about the same. I dont like going under 18-20 psi bc it makes them a little squirrely at high speeds and around corners.
I run max on side of street tire (any brand ) most ask for 44 max and get 40-43 k miles of good even wear each set, Nitto and MT drag radials on the street are another story 22-24 # and get 1-2 k milage
Johnny
Johnny
