30# svo injector limits??
Old 05-14-2009, 02:09 PM
00 black ss's Avatar
Default 30# svo injector limits??
Would these injectors hold up on a ms3 full bolt on and spray car? Or do I need bigger injectors then that? If so what size would I need and what brand should I get that are on the cheap side?
Old 05-14-2009, 02:28 PM
ZL1Killa's Avatar
Nope. You will need 37# or 42#; I recommend 42#, in my experience even on a stock car 42# injectors are nice and are easy to tune without any hiccups.
I use racetronix. RCENG.com can build you some. or FIC Injectors up here is a sponsor
PLEASE PLEASE PLEASE look at my fuel and injection sticky and educate yourself, PM me if you have questions. RCENG
My Fuel and Injector Sticky
Old 05-14-2009, 03:17 PM
7 Second Club
NicD's Avatar
If you are talking a wet kit then yes, those 30# injectors are adequate. The 30# ford injectors are good to around 470-480 rwhp from what I have seen and you won't be near that with a cammed setup.
Old 05-14-2009, 06:34 PM
ZL1Killa's Avatar
the reason the 30# are good for that is that they are rated at 43.5psi, and our pressure is ~58psi
Old 05-14-2009, 08:25 PM
So really the 30# injectors are 43# injectors? And since if I'm getting a wet kit injectors don't matter I'm guessing?
Old 05-14-2009, 08:38 PM
FICINJECTORS's Avatar
no they flow 36lb at 58psi 36's flow 42, 42's flow 50
