help my car wont move
I have a 1999 camaro with a EL60 automatic trans. I was driving my car and all of a sudden the car wouldn't move. I noticed the trans lines from the trans to the radiator where not hot. Could the pump have went out. If so what is the cost to get it fixed. I can take the trans out and put it in. My car does have around 500hp to the flywheel so I new this was going to happen sooner or later. Thanks
Just for future reference the trans is a 4L60E. I would say it does sound like maybe a pump. Unhook one of the lines and start it for a second and see if you get any fluid, if you get no fluid then its for sure the pump. I am not sure how much it would be to just change out the pump but if you are going to pull the trans and you have not built the trans yet it would be a good time to do it.
