New 402ci in my Z06
New 402ci in my Z06
Hi
i just bought new short-block whith cam from Texas speed & performance
it will be shipped to me to Iceland next week.
This is LS2 402 Aluminum Block
Eagle LS1 4.00-Inch Stroke Crankshaft,
24X Tooth Reluctor, With ESP Armor Finish
Eagle LS1 6.125 H-Beam Connecting Rod Set with Upgraded ARP
2000 Rod Bolts, 2.100 Crank Journal, .927 Wrist Pin
Wiseco Forged LS1 Piston Set: 4.005" Bore, 4.000" Stroke, 6.125"
Rod Length, -8cc Dish, 1.115" CH;
Wrist Pins & Steel Top/Napier
whith cam installed: Texas Speed & Performance Texas Giant V2 Camshaft: 248/254,.615"/.622", 114 LSA
Precision Race Components Gold Spring Kit With Titanium
Retainers, Seats & Seals for te heads..
i´m gona use my TFS 215 cc heads,
my harland-shapard 1.7 rockers, 7,700 pushrods
new LS7 lifters
and the orginal ls6 throttle body and intake,
Mti ramair
my bigger injectors
MSD
new SLP 25% underdrive pulley
my kooks headers. (no cats)
and bought new disc in my Spec lll clutch
Hurst shifter/hurst line lock
Texas Speed & perf. Map-tuning.
got NGK AFX Wideband Kit
how does this sound.....?
what can expect rwhp whith my setup.?
can i porte my intake manifold, and use the ls6 throttlebody?
kv Baering
Iceland
new LS7 lifters
Mti ramair
my bigger injectors
MSD
kv Baering
Iceland
1 Post
Sounds good other then the intake/tb. It will hold you back for sure. A ported FAST 90 or 92 with a 90mm tb or 95mm like I am using with the intakes inlet opened up to match. When my tb's were swapped from 90 to 95 mm's I picked up 6.xx rwhp and 17.xx rwtq. The larger tb definately helped her breath.
Yes but the ls2 intake manifold flows worse than the ls-6-go figure. If you search(since I don't know where) they have a few places that port and seal the ls-2 manifold and it flows almost as well as a fast. you can get them for fairly cheap and I think there is a core charge.
is it difficult to port this intakes,
how wide is the orfginal ls2 85mm?
ok
thanks
but, tell my, my injectors
i´m not sure what type they are,
it says on them on one side 621030 an the other D1163AA
if i google them i see often lucas something 38lb. and some 40# and sometimes i see 42lb.
but on my other setup, 346ci, tfs 215cc and cam 232/234. 595/598 112l it was often rich of fuel...
so do you know anything about these injectors.
is 38lb, ok on my 402.... whith that setup...
kv baering
i run the fast 36lb injectors on my 402, i shouldve gotten the svo 42s. My duty cycle on motor gets as high as 87% above 6500rpm. I havent sprayed it yet to see what that does. Wet system
1 Post
ok
thanks
it says on them on one side 621030 an the other DLL63AA
if i google them i see often lucas something 38lb. and some times i see 42lb.
kv baering
thanks
kv baering
LGM said I would be marginally safe with my 30#svos. Marginally safe wasn't good enough for me so I got the 42#'rs. I think you will need the same.
N/a duty cycle of 87% is nothing, but if you run a big shot you'll likely go beyond 100%. Be careful on how big shot you put on your current fuel setup.
[QUOTE=allngn_c5;11616780]LGM said I would be marginally safe with my 30#svos. Marginally safe wasn't good enough for me so I got the 42#'rs. I think you will need the same.
ok but if my injectors are just 38lb, are they not good enough, maby buy bigger injectors, when i buy fast 92mm, and new throttlb. maby next winter????
bu like i said if i google these part numbers 621030 D1163AA they are showing it from 38lb up to 42lb, nobody seemes to know for sure, so how will i know what i´m running, maby when i tune??
