2007 LS6 into Camaro?
Old 05-17-2009, 01:55 PM
maxgee's Avatar
Default 2007 LS6 into Camaro?
What do I need to put an LS6 into my Camaro? Also, what type of boost can the LS6 handle under stock form?
Old 05-17-2009, 03:41 PM
99LS6SS's Avatar
Mine dropped right in. I used the 04 CtS-V oil pan and pick up and it clears perfect. You'll need a tune sooner or later. And about the boost, I don't think it will be able to handle much in it's stock form with 10.5:1 compression. Maybe 6-8, and possibly 10 with meth.
Old 05-17-2009, 05:57 PM
maxgee's Avatar
Thanks for your reply.
Old 05-18-2009, 07:21 PM
elias_799's Avatar
i would throw some 317 heads on there to lower the CR. 10.5:1 is a Little high for an FI street motor
Old 05-18-2009, 08:33 PM
maxgee's Avatar
left deposit and picking up tomorrow.
Old 05-18-2009, 10:30 PM
baylove's Avatar
congrats
Old 05-18-2009, 10:54 PM
ls2 bait's Avatar
and they didnt make an ls6 in 07. you are sure its an ls6 right?
Old 05-18-2009, 11:31 PM
elias_799's Avatar
^^ yea they stopped putting them in production cars in 05, but i think gm still makes and sells them as a crate motor. hopefully that is what he is getting
Old 05-19-2009, 10:13 AM
99LS6SS's Avatar
Yah they still make them as crate units. What motor is it exactly?
Old 05-19-2009, 10:17 AM
Big_Bird_WS6's Avatar
you have a cts-v oil pan on you f-body?
why not just use the f-body oil pan? do you get more oil or what?
Old 05-19-2009, 02:27 PM
99LS6SS's Avatar
Yah it's a bigger capicity, plus I ordered it with that pan set-up cuz it was cheaper. I tried to swap the f-body oil pan and pickup onto the new motor, but the windage tray was diffrent I believe, or something was different, I can't remember, but the windage tray was cut in half and smashed up from a rod going through my old motor. So it was cheaper to use the CTS-V oil pan and pickup
Old 05-19-2009, 02:33 PM
99LS6SS's Avatar
I think it's a 6.5 quart I believe. I buy seven quarts, fill the filter with half a quart, and the rest goes in the pan.
Old 05-20-2009, 03:02 PM
https://ls1tech.com/forums/conversio...-oil-pans.html
^^^ this says they are both 5.5 quarts?
Old 05-20-2009, 04:42 PM
99LS6SS's Avatar
http://www.cadillacforums.com/forums...ity-cts-v.html
I take it we were both wrong...I asked at O'Reilly's when I was buying oil to put in when i was dropping my motor in, they told me 6.5...which is right by the service manual, but it's 6.5 including the 1/2 quart in the filter. I don't have any problems with it...
Old 05-21-2009, 10:31 AM
lol lol
Old 05-22-2009, 02:27 AM
archerandsons's Avatar
i got cts-v and i put in 6.... none in filter.... runs great....
Old 05-22-2009, 08:00 AM
ok so which on of you are going to check your dip stick and see which is right?
Old 05-22-2009, 09:15 AM
99LS6SS's Avatar
Well I guess I could check it...wouldnt the dip stick be different on mine since I used the f-body dipstick
Old 05-22-2009, 10:08 AM
dip stick goes into the block. so it should always read the right amount for the block. so if you have 5.5 quart f-body for 8 quart moroso. it should read right when full
Old 05-22-2009, 08:49 PM
elias_799's Avatar
i fill up my oil filter with oil every time i do an oil change, you should do it all the time, especially if you have a turbo car.
Quick Reply: 2007 LS6 into Camaro?
