GM Perfomance Parts sleeves???
Part # 12480004. Cylinder sleeves (standard) "These sleeves are for new design aluminum V8 and V6 90 blocks. Technical Note: This sleeve has a 3.980" ID and can be bored to 4.125"."
Will these work on Gen 3 Design blocks?? Stock LS1 has a 3.98 bore size and the Racing Block (C5R) has a 4.117" bore. Could this work???
Stock LS1 has a 3.90 bore.
I doubt these are for the LS1. Even if they are, my understanding is that resleeving these blocks is more about technique, not the sleeve. I think you can buy dry (or wet) sleeves from Darton.
