New build break-in
New build break-in
Got my 355 all together and I'm curious if there is a break-in precidure I need to do and what kind of oil I should run at first to break it in?
i put cheap 5w-30 in mine let it get to temp then changed it and the filter. make sure to fill the filter with oil first. then i drove around 400miles putting a load on the motor and letting the car engine brake. 7k on it now and dosent leak or burn a drop compression check was good.
