95 TA Convert to T56 can i use 96 computer??
ima drop the motor n tranny back out... ima put the t56 in out of a 96... think i can use the pcm out the 96 in the 95 body??
(95 is OBD1) (96 is OBD2)
The beautiful thing about switching to a manual transmission, is that it's manual (duh) no computer involvement whatsoever. Just keep the same computer you have and flash the PCM to a manual trans tune. Or just ignore the 12 or so codes that you'll throw after the swap.
